Home » Sponsored » Pi Speakers » Soffit (Flush Mount) Reference Speakers (Studio Control Room (Mid-field) Monitors for Full Range Reference)
Re: Soffit (Flush Mount) Reference Speakers [message #65293 is a reply to message #65292] Wed, 15 December 2010 19:19 Go to previous messageGo to previous message
I would suggest simply building the speakers as designed and mounting them in the wall. If you can close the gap so the wall is the baffle, that's great but as long as the gap is small it is acoustically invisible.
Radiating into half-space does increase sound compared to freespace. The so-called baffle-step compensation is done to conjugate the transition from the region where the baffle is acoustically large to where it is acoustically small.
At low frequencies, the baffle is acoustically small so sound radiates omnidirectionally. At high frequencies, where the baffle is acoustically large (i.e. large compared to wavelength), the front of the speaker causes the sound to radiate into halfspace. (Unless of course the driver's directivity is already making a tighter beamwidth anyway)
So what you have here is changing directivity, and this causes on-axis response changes. It does not modify the power response though. Power response is the total energy radiated in all directions. On-axis is the response straight forward. So if a speaker has constant directivity, they're equal. If not, then the on-axis response changes as beamwidth changes.
π Speakers generate uniform directivity so baffle step is non-sequiter. They're designed to be used with their backs against the wall already. But to tell the truth, there are still some transitions between where the baffle is acoustically small to large, and then again where the room has influence, and wall mounting will help this. So there is a benefit in soffit mounting like that.
And don't forget multisubs...
By the way, here's another good link of permanent installation:
Previous Topic: 4 Pi vent question
Next Topic: 7 Pi without mid-horn?
Current Time: Fri Nov 20 15:18:43 CST 2026
