Home » Sponsored » Pi Speakers » Soffit (Flush Mount) Reference Speakers (Studio Control Room (Mid-field) Monitors for Full Range Reference)
Re: Soffit (Flush Mount) Reference Speakers [message #65290 is a reply to message #65288] Wed, 15 December 2010 18:44 Go to previous messageGo to previous message
We don't offer any single driver loudspeaker kits, so I'm not sure if this will help. But if you're looking for monitors that offer uniform directivity, I can help.
All models of π Speakers are available as kits, which include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
I would suggest the three π or four π models with the upgraded drivers for best quality sound. From the looks of your room, the end result would be something like this:
index.php?t=getfile&id=169&private=0
Previous Topic: 4 Pi vent question
Next Topic: 7 Pi without mid-horn?
Current Time: Fri Nov 20 15:18:46 CST 2026
