Home » Sponsored » Pi Speakers » Best choice for my set up
Re: Best choice for my set up [message #65240 is a reply to message #65239] Sat, 11 December 2010 10:31 Go to previous messageGo to previous message
If you want all-out best, use six π or seven π cornerhorns if you can put them in corners, or three π or four π mains if corner positioning isn't possible. If using three π or four π speakers, put them on stands to get them up to the level of the screen. Either way, go with the upgraded drivers.
If you're working with a budget, you can skip the upgrades or step back to something like the two π towers for mains.
Surrounds should be at the sides and slightly above the listeners. One π or two π speakers work great as surrounds.
Don't use just one sub, go with at least two. You want bass sound sources to be distributed through the room rather than a single source. This helps smooth room modes.
Previous Topic: A question of wood thickness
Next Topic: Three π f3, f10?
Current Time: Wed Nov 04 15:14:29 CST 2026
