Home » Sponsored » Pi Speakers » A question of wood thickness
A question of wood thickness [message #65197] Wed, 08 December 2010 07:17 Go to previous message
tman is currently offline  tman
To build Pi2 Towers you recommend to use panel of 5/8" (that is
almost 16mm). But if I want to cover them with a foil of 4mm
plywood, must I use panels of 12mm? Or have I better to use panels
of 14mm (for example), making a little larger port?
And what about mdf for panels? Is it a good solution?
Previous Topic: Attaching Crossover Components
Next Topic: Best choice for my set up
Current Time: Thu Nov 05 01:49:02 CST 2026
