Home » Sponsored » Pi Speakers » Attaching Crossover Components
Re: Attaching Crossover Components [message #65188 is a reply to message #65065] Mon, 06 December 2010 23:40 Go to previous message
I put mine on a small piece of thinner baltic ply. I screw 3 tag strips on an edge, the middle for input, and the two outside ones for output to the drivers. I also connect the compensation parts for the cd to it's output tag strip in a trick way. I use tie straps with the screw anchor for big parts, and use blue tack for all the parts on the board. I screw all this onto an inside surface, with neoprene washers and more blue tack.
Previous Topic: Pi4 plans
Next Topic: A question of wood thickness
Current Time: Wed Nov 04 17:26:59 CST 2026
