Home » Sponsored » Pi Speakers » Cure for brightness
Re: Cure for brightness [message #64886 is a reply to message #64880] Wed, 24 November 2010 22:22 Go to previous messageGo to previous message
Your complaint reminds me of the Piezo tweeter days. I'd look at the room.
The Vifa XT 25 tweeter is 2 dB less efficient than the Alpha 8 as Wayne said and, compared to other domes, is in the less-fatiguing/detailed camp. The Zaphaudio test called it "the smoothest and most extended response curve....".
http://www.zaphaudio.com/tweetermishmash/
Get some good room treatment advice at the Rives Forum; for instance, 1" thick stiff fiberglass (Owens-Corning 604) panels offset from the wall 2" will attenuate frequencies from 1500 Hz up. Add drapes, try live-end, dead-end, move reflective surfaces like glass-covered paintings and mirrors, etc.
If you must re-cap, I'm a big fan of the copper Obbligatos as well as old Aerovox motor runs in the oval cans. Use'm in all my stuff.
Previous Topic: Port length for 2pi studio
Next Topic: 4 Pi plans
Current Time: Wed Oct 21 06:31:17 CDT 2026
