Home » Sponsored » Pi Speakers » Cure for brightness
| Re: Cure for brightness [message #64880 is a reply to message #64879] |
Wed, 24 November 2010 14:58   |
Some oil-filled motor runs are pretty good, reasonably priced and tend to warm up the sound. I'd be interested to hear what you think of them. Be sure to get an oil-filled can, because there are other kinds of motor run caps these days, most of them using some kind of plastic dielectric. Some of them are pretty cheap and nasty. So when searching for oil-filled motor-run caps, don't just look for "motor run", also look for "oil" or "dielectric fluid".
I don't think you'll hear a difference with a Mundorf M-Series because it is basically the same as the stock cap. But the price isn't too bad either, about the same as the Solen that came with the kit. The Supreme and some of their other series are more expensive, and I'm not sure it makes sense to use in this speaker. Guess you could if you wanted to.
The Obbligato might sound different to you, but my guess is it will sound the same, or at least too close to call. It's like the Auricaps in price and, I suspect, in sonic character.
I've used Audio Note capacitors, Mundorf Supremes, Jantzen Superior caps and Auricaps and find each of them to be nice, but then again at those prices, you would expect them to be. I tend to reserve these higher-priced caps for the speakers with premium driver options. The JBL and AE drivers are pretty expensive, and justify using capacitors in the $20 to $200 range, at least in my mind. The speaker drivers cost several hundred bucks, so a hundred or two hundred dollars spent in the crossover parts is probably well-deserved. But to be honest, I can't see spending more on the passive components than the drivers cost.
That said, none of the capacitors you've mentioned cost more than the drivers, and I wouldn't wince at their price tags. I think that Obbligato is the most expensive of the three you've mentioned, at about $25.00. The Mundorf MKP is about the same as the Solen, about $7.50. Motor runs can be bought for just about any price, from less than ten bucks to who knows what. But none of these is really outrageously priced. Might be worthwhile to try them all, especially if you already have them on hand.
Cure for brightness
By: notben on Wed, 24 November 2010 13:05
By: steve f on Wed, 24 November 2010 13:58
two π speaker response curve
By: notben on Wed, 24 November 2010 14:29
By: notben on Wed, 24 November 2010 16:06
By: steve f on Thu, 25 November 2010 04:15
By: GarlandB on Thu, 25 November 2010 11:32
By: Matts on Thu, 25 November 2010 18:36
By: Adveser on Thu, 25 November 2010 23:40
By: notben on Fri, 26 November 2010 11:08
UPDATED Re: Cure for brightness
By: notben on Sat, 22 January 2011 15:02
Re: UPDATED Re: Cure for brightness
By: biglaz on Sat, 22 January 2011 19:40
By: notben on Sat, 22 January 2011 20:58
By: biglaz on Mon, 24 January 2011 17:09
Current Time: Wed Oct 21 07:42:16 CDT 2026
