Home » Audio » Speaker » Computer Speakers for TV?
Re: Computer Speakers for TV? [message #64793 is a reply to message #64771] Sun, 21 November 2010 20:23 Go to previous messageGo to previous message
does the 9-pin connector hook up the speakers? that usually how these things are configured. If not, was it plugging into to work? I wouldn't do anything unless you know if any of the speakers or the sub is drawing "phantom power" from another component. If everything is passive, you can simply cut wires and twist the right connector into place and ground down the unnecessary poles on the 9-pin connector. The fact they are there suggests something is sending power to something else.
Previous Topic: Speakers for around the pool
Next Topic: Flat Speaker
Current Time: Fri Sep 11 18:38:31 CDT 2026
