Home » Audio » Group Build » Sound Boxes - Calculating Dimensions (How do we calculate the dimensions of a sound box?)
Re: Sound Boxes - Calculating Dimensions [message #64790 is a reply to message #64110] Sun, 21 November 2010 16:43 Go to previous messageGo to previous message
There is a correlation between the diameter of a bass driver and the box volume, but other factors enter the equation too. Many years ago determining the right box size and port dimensions was a trial and error thing, and when a design did sound right nobody knew why. Then two guys named Theile and Small identified the mathematical correlation between driver parameters and box size and tuning, and the world has never been the same.
Check out some drivers on any speaker site and you will notice some parameters known as the TS parameters will be listed. This include VAS, QES, QMS, QTS, etc. You can use these to calculate the optimum box size and tuning using any of a number of calculators. One of the most popular is WinISD, which can be downloaded free from this site: http://www.linearteam.dk/default.aspx?pageid=winisd
You can plug in the TS parameters of a driver and the program will suggest an optimum box size and tuning (if the driver is appropriate for a tuned box), and will show a freq resp graph. You can change the box size and tuning, and the graph will indicate the changed freq resp and other characteristics.
Download WinISD and not WinISD Pro. It's simpler to use. And be sure when you enter data you're using the right measures (e.g. don't confuse cu liters with cu ft, etc.
Previous Topic: Art Array Improved Crossover
Next Topic: ART Arrays for Home Theater
Current Time: Sat Nov 14 22:45:52 CST 2026
