Home » Audio » Source » Dumb question
Re: cassette repair [message #64563 is a reply to message #64561] Tue, 02 November 2010 10:34 Go to previous messageGo to previous message
Heat usually distorts the cartridge, or in some cases completely melts it. What I would do, if I were you, would be to get a bunch of empty cartridges or sacrificial tapes and remove the magnetic tape spools, replacing them with the ones you want to keep. It is easiest if the cartridges are assembled wih screws, because then the two halves can be easily separated and reassembled. But I find even those that are glued together can be split pretty easily with a razor blade, and then reassembled with glue. Just be careful.
Previous Topic: Favorite Condenser Mic for Vocals?
Next Topic: Do they still sell
Current Time: Fri Nov 13 06:50:00 CST 2026
