Home » Sponsored » Pi Speakers » Pi2 and woofer directivity
Pi2 and woofer directivity [message #64540] Thu, 28 October 2010 14:15 Go to previous message
RDLewis is currently offline  RDLewis
Hello Wayne,
Over the years you have written many pages on matching sensitivities, phase, directivity, etc, using 2way woofer/CD horn systems, but I have not seen a lot in a similar vain on the Pi1 and 2?
You discribed the crossover of the "1" and "2", as using a "pseudo" first order for the bass levels off the rising Fq response and a cap and shunt resistor on the tweeter. I presume this goes someway to getting the phase right(?). But I would be very interested know how you set out to achieve your favored "controlled directivity" with a domed tweeter? Or had other objectives with above?
You have mentioned that Pi2 Towers are in regular use in one of your systems and I see they are at the top of the list of best sellers. So how do they compare with the more expensive proper CD Horn in imaging and control?
I would be grateful if you could enlighten us all.
Thanks
Roy
Previous Topic: 12pi plans
Next Topic: Pi4 New Owner
Current Time: Fri Oct 23 09:48:39 CDT 2026
