Home » Audio » Home Theater » Open Floor Plan
Re: Open Floor Plan [message #64434 is a reply to message #64428] Fri, 22 October 2010 10:00 Go to previous messageGo to previous message
Generally, open spaces are easier to work with than small rooms, at least where acoustics are concerned. I'd probably put the main speakers on stands flanking the TV, left and right and at about the same height or maybe just a smidge below. Then put the surrounds beside you and maybe a little bit behind you and slightly above ear level.
Previous Topic: New Home Theater receiver.
Next Topic: Blu-ray home theater, is it worth it?
Current Time: Sun Oct 25 12:38:35 CDT 2026
