Home » Audio » General » Buzzing mic
Re: Buzzing mic [message #64388 is a reply to message #64369] Tue, 19 October 2010 18:31 Go to previous messageGo to previous message
There is a short in the ground wire. If you using a 1/4 adapter make sure that the ground and the negative poles are soldered together or use an XLR to XLR cable.
Get a mic stand that is not using metal to hold the mic. All the ones I've used use plastic harnesses. Or wrap the mic housing is electrical tape.
Previous Topic: Invention of the first Audio Equipment
Next Topic: Advice for the ignorant?
Current Time: Sun Nov 01 03:59:21 CST 2026
