Home » Audio » General » Buzzing mic
Re: Buzzing mic [message #64370 is a reply to message #64369] Mon, 18 October 2010 12:30 Go to previous messageGo to previous message
I think you probably just have a loose mount. Gently tap the microphone and listen for the buzz. Try to tighten anything that appears to be loose.
There is another possibility. I doubt this is it, but you should be aware. Microphones can sometimes act like loudspeakers. If they are fed a drive signal, they can produce a sound. So if the stand provides a ground and the signal line is floating, it is possible that the microphone will complete the circuit and buzz. If that's the case, it won't probably live long. The singers might not either, if you have a hot mic. Laughing
Previous Topic: Invention of the first Audio Equipment
Next Topic: Advice for the ignorant?
Current Time: Sun Nov 01 03:59:23 CST 2026
