Home » Sponsored » Pi Speakers » Just bought some JBL 3677...? about the CD and horn
Re: Just bought some JBL 3677...? about the CD and horn [message #64326 is a reply to message #64325] Wed, 13 October 2010 16:42 Go to previous messageGo to previous message
I think so, yes. With the back so close to the woofer, you'll have no choice, really, because you don't want damping material sucked into the cooling vents. That would make them turn into one-way valves, which would not only affect cooling but would change tuning and even introduce a slight amount of asymmetry in cone motion. So keep the damping material away from the woofer's cooling vents.
Previous Topic: NOS 1 PI's
Next Topic: 4pi
Current Time: Fri Nov 13 00:43:48 CST 2026
