Home » Audio » Speaker » Golden ratio for loudspeaker cabinets
Re: Golden ratio for loudspeaker cabinets [message #64318 is a reply to message #64313] Wed, 13 October 2010 12:49 Go to previous messageGo to previous message
Odd shapes help breakup standing waves, yes, much the same as the Golden Ratio proportions do. Both have the same goal. Internal damping from properly placed acoustic insulation helps a lot too.
You can make the height have 1.618-to-1 ratio to the width, and width be 1.618-to-1 with respect to depth. Or you can angle a panel. Or both. Just remember, though, that these are helpful hints, suggestions to put you in the ballpark, so to speak. You may still have a standing wave node that influences response even with Golden Ratio or trapezoidal box shape. For best results, you should measure the cabinet acoustically to be sure, making adjustments as necessary.
Previous Topic: Motorcycle Speakers
Next Topic: Active vs. Passive Crossovers
Current Time: Wed Oct 21 19:18:23 CDT 2026
