Home » Sponsored » Pi Speakers » Kappalite 3015, DE250, QSC 152i waveguide
Crossover optimization [message #64305 is a reply to message #64302] Tue, 12 October 2010 13:16 Go to previous messageGo to previous message
Crossover prices are per board.
The required attenuation will probably be something like 12dB or 14dB. You can easily match sensitivities of midwoofer and tweeter with π pad R1/R2 values but it takes a design/test cycle to set the position of the forward lobe and vertical nulls. You probably shouldn't assume that the Kappalite 3015 will work as a drop-in replacement for the JBL 2226 or the Omega 15. There are differences that may require crossover changes in the low-pass network. The link below describes the process I use to optimize the crossover for the drivers chosen.
Previous Topic: 4Pi Plan Request please :-)
Next Topic: 4pi
Current Time: Wed Sep 02 09:48:55 CDT 2026
