Home » Audio » Speaker » Golden ratio for loudspeaker cabinets
Re: Golden ratio for loudspeaker cabinets [message #64297 is a reply to message #64296] Tue, 12 October 2010 11:12 Go to previous messageGo to previous message
Well, 15" wide and 40" tall is a ratio of 2.667-to-1, not 1.618-to-1 or even close. Not that this is necessarily bad but at 40", you'll definitely want to analyze internal standing waves. There will be pipe modes in the passband, if this is a full range speaker. Depending on what you're trying to do, that may or may not be a good thing. For instance, transmission lines depend on them. But it is something you'll need to explore for best performance.
Previous Topic: Motorcycle Speakers
Next Topic: Active vs. Passive Crossovers
Current Time: Tue Oct 06 19:33:38 CDT 2026
