Home » Audio » Home Theater » How big should a sound system be? (I don't know what size the speaker here should be in my sound room)
Re: How big should a sound system be? [message #64122 is a reply to message #64120] Tue, 28 September 2010 01:19 Go to previous messageGo to previous message
Well, I used to think size was the indicator of quality, but that has not been the case in a long time since they've been able to make smaller speakers with much bigger outputs than they used to.
It is all about the power output of the drivers, really.
I really don't know what you are asking. 120db @ 2 meters is how loud a sound system should be as far as i'm concerned, for home listening. I couldn't tell you what wattage would be necessary to get that.
As far as the physical size of a speaker I say the bigger the better. Get something that outputs the power you want and has the f bandwidth that is required. An 8" speaker might do it or a 16" one might do it it all depends on the size of the magnet.
Previous Topic: Suggestions for new system
Next Topic: Acoustic Research AR HC6
Current Time: Sun Nov 01 06:34:58 CST 2026
