Home » Audio » Craftsmen » I know you hate t-nuts so (mounting drivers)
T-Nuts [message #64018 is a reply to message #64017] Fri, 10 September 2010 00:03 Go to previous messageGo to previous message
Yeah, the tangs will fold up if you beat them in, especially the cheap ones. But when I pull them in with a screw, I don't have any problem, even in strong baltic birch plywood. I think adding the dab of glue helps too, because the biggest problem is having one come loose.
This process works very well for me, and it's important to have a 100% solution in my basshorn subs because a failure would cause a major repair problem, possibly even turning a $3000 cabinet into scrap. The woofers are mounted internally, and you can't really get behind the panels to access the T-Nut once it is in place. It is a long way inside the cabinet, behind panels that are buried inside.
Previous Topic: Effect of Length
Next Topic: This weeks musical projects
Current Time: Mon Nov 30 12:00:28 CST 2026
