Home » Audio » Radio » Zenith Transoceanic G500 restoration (need help)
Re: Zenith Transoceanic G500 restoration [message #63906 is a reply to message #63902] Mon, 23 August 2010 00:14 Go to previous messageGo to previous message
dsumerfi is currently offline  dsumerfi
Wayne,
Thank you for the response. I tested that resistor and it appears to be bad - no resistance across the leads! I am also curious if you've seen capacitors like the green ones on the right side of the picture in the original post (attached to the ocs. coil). I think they are represented in the schematic by the 150 MMF capacitors, but I haven't been able to confirm that by internet research, and that stripe pattern doesn't seem to match the values on the schematic with any stripe rating schedule I've found.
index.php?t=getfile&id=253&private=0
Also, I'm not sure what the other four capacitors in that portion of the schematic are rater for - they're the only ones without values. I think I've located them in the radio, but once again, some of them are the green style which I can't decipher.
Any thoughts?
Thanks in advance.
Daniel
  • Attachment: Untitled.jpg
    (Size: 86.93KB, Downloaded 7547 times)
Previous Topic: 37-93
Next Topic: Atwater Kent Shortwave model 37
Current Time: Mon Nov 02 09:29:29 CST 2026
