Home » Audio » Radio » Airline 62-2704 Need Help (Need help finding information on this radio)
Re: Airline 62-2704 Need Help [message #63545 is a reply to message #63541] Tue, 27 July 2010 19:46 Go to previous messageGo to previous message
Encryptor is currently offline  Encryptor
I may be able to make it work with some wooden brackets off the screws that are there for the 10".
I know but that is difficult to do when the speaker is gone and there are no schematics that I can find for this specific radio.
Do a Google search for a Gamble-Skogmo inc. Model 43-6927 and a Model 43-7603. They look like the same chassis but the latter has the phonograph in it. The picture of the back of the cabinet of the first model is easier to see the speaker. I don't know if you can tell if it's a field coil speaker from the picture or not.
The problem again is I don't know if this is identical to the one I have although the chassis top view looks to be identical to mine.
Thanks again for your help.
Previous Topic: DC. BLOCKING CAPS
Next Topic: Transistor Radios
Current Time: Thu Nov 19 11:22:23 CST 2026
