Home » Audio » Speaker » Socket Splitter Problem
Re: Socket Splitter Problem [message #63475 is a reply to message #63473] Wed, 21 July 2010 21:29 Go to previous messageGo to previous message
Keith Larson is currently offline  Keith Larson
This is because the volume control of your headset is probably a simple potentiometer with the (headset) drivers hanging from the wiper. As you move the wiper to the full volume position, the impedance of the drivers in parallel with the potentiometer is seen. If the wiper is at minimum volume, the impedance is only that of the potentiometer.
A more sophisticated way of doing this is to use an L-Pad for the volume control. In this case there are two wipers (two for each side, so there are four for stereo). As one wiper goes up, the other goes down keeping the impedance relatively constant. Or, at least thats how the theory goes. In reality the complex impedance of the driver gets involved.
As you may expect, L-Pads are rare in headphones as the optimal solution is to not have a volume control at all. Most of the time you find L-Pads in midrange and tweeter controls. The idea is the same, to keep the impedance relatively constant (IE an L-pad is better than a simple single potentiometer), because the changing impedance can result in some odd effects in the crossover.
Previous Topic: Wireless speakers
Next Topic: Weird speaker
Current Time: Mon Nov 30 11:47:59 CST 2026
