Home » Audio » Home Theater » big screens
Re: big screens [message #63418 is a reply to message #28657] Sat, 17 July 2010 05:14 Go to previous messageGo to previous message
JiminyCricket is currently offline  JiminyCricket
In terms of size, try using the math formula someone told me about.
Basically, with a HDTV you simply measure the screen (n inches) and then work out if you can comfortably sit between 1.3 - 3 times that measurement away from it.
If you can then go ahead. If not, then sorry but your room is too small Smile
I agree that the sound should match the size - too much in a small room seems pointless.
Previous Topic: VCR
Next Topic: What do you have?
Current Time: Sat Oct 17 12:04:03 CDT 2026
