Home » Audio » Thermionic Emissions » EL156
| Re: EL156 [message #63397 is a reply to message #63116] |
Wed, 14 July 2010 10:12   |
SASAudioLabs
Messages: 17 Registered: May 2009
Chancellor |
| gofar99 wrote on Wed, 09 June 2010 21:08 | Hi, I just got a quad of the EL156s for a friend who asked that I audition them before sending overseas to him. Such a deal. Physically they are a bit taller, but similar in construction to KT88s. As the designer of the OddBlock series of class A U/L push-pull amps these were an opportunity to push the envelope a bit for free. For comparison, I normally use JJ Blue Glass KT88s and for lower power JJ Blue Glass EL34s. I have tried many brands and types - but these seem to suit me best. The rest of the system is a modified Marantz CD5001 player, a preamp that I designed that will operate as active (tube) or passive, the OddBlocks, and Martin Logan Vista ESLs. For vinyl, a Dual 701 with Grado Prestige cartridge and a modified transistor preamp (I have a tube one in the works now). So back to the sound. I ran the EL156s at the same power level as the KT88s (450 B+ and 180 ma per pair at idle). The 156s are considerably more sensitive than the KT88s (expected if you look at the bias settings). The sound was powerful, very solid bass, almost too much, mids and highs very crisp. The sound was right in your face. Good sound stage width, good detail. Things like cymbals and bells were well sounded. Generally a great set of tubes for rock music. By comparison the JJ Blues are much more polite. Well rounded, not quite as much bottom end, very lush sound while maintaining the detail and separation well. The 156s could easily been pushed about 25% for more power if needed and I would expect the sound to be pretty much the same. Overall, a pretty good tube if you like your music crisp and powerful.
BTW I have a quad of matched KT120s coming next week. They could be really killers if they sound decent.
Hope this helps,
As you know, the sound quality is dependent upon the design and brand parts used. Using a design and brand parts for a KT-88 is not going to be the same as one for the EL-156.
As an example, playing Stereophile 2, track 10, soundstage; the gent was easily 40 feet behind the mic (speaker) when he was so, and at the mic (speaker) when he was so. As I said, depends on the design and parts used if you wish it in your face or more relaxed etc. I listen to classical and rock all the time with great soundstage. No problem with bass, but that would depend upon the speaker/woofer, Q, room resonances/treatments etc.
Cheers.
ps. Here is a picture of test amps from the 2009 AKfest using KT88s, before I changed the design to EL-156s.
Attachment: ak9amp.jpg
(Size: 59.34KB, Downloaded 6989 times)
Current Time: Sat Oct 17 00:08:15 CDT 2026
