Home » Audio » Radio » Edison type 7R (tube radio)
Re: Edison type 7R [message #63237 is a reply to message #63236] Wed, 23 June 2010 10:34 Go to previous messageGo to previous message
Well, OK, cool. You can check the tubes then. Your tester will test those tubes, I hope?
Swap the caps, test the tubes and make sure they're all good. Hopefully that will get her going...
Previous Topic: Fm Antenna success
Next Topic: Improving radio reception
Current Time: Tue Oct 27 16:59:28 CDT 2026
