Home » Audio » Radio » Edison type 7R (tube radio)
Re: Edison type 7R [message #63235 is a reply to message #63234] Tue, 22 June 2010 22:06 Go to previous messageGo to previous message
That is so, so cool! Love the cotton insulated wire. Chassis looks like it's in pretty good shape, just needs a little cleaning.
The 60Hz hum symptom is a pretty common one. It can mean just about anything. Could be as simple as coupling caps gone bad, and if they haven't been replaced, that's likely. I generally replace all paper/oil caps with polys, first thing. Could be a tube too, or alignment, but I'd start with the caps.
Do you have a tube tester? An oscilliscope?
Previous Topic: Fm Antenna success
Next Topic: Improving radio reception
Current Time: Tue Oct 27 17:01:53 CDT 2026
