Home » Audio » Radio » 37-93 (philco)
Re: 37-93 [message #63221 is a reply to message #63220] Mon, 21 June 2010 17:53 Go to previous messageGo to previous message
To post pics, just upload them with the "File Attachments" tool below your reply window. Click the "Browse" button and find the image file on your computer. After uploading, you can click the link that says "Insert image into message body".
As for the electrolytics, I usually just replace the whole can. Most times, in old tube radios, the electrolytics are pretty small by today's standards. A lot of them are 10uF or 20uF, which I replace with poly caps. They are available with pretty high voltage limits, so they are suitable for tube amps. I have had a few radios with dual and even triple caps in one can, which I replace with separate individual poly caps.
Previous Topic: Radio in the 21st c
Next Topic: Zenith Transoceanic G500 restoration
Current Time: Mon Nov 02 10:31:01 CST 2026
