Home » Audio » Speaker » The Bumma (tentative title) (2 way CD horn system)
icon10.gif  The Bumma (tentative title) [message #63191] Thu, 17 June 2010 17:40 Go to previous message
badman is currently offline  badman
Finally done from a build perspective is my waveguide, a 15" contour, 16.5" overall assembly. Made of resin, epoxy, plywood, styrofoam, casting cloth, and a few other odds and ends.
Crossover is being worked on, and I'll post more XO details as it gets refined. Currently the woofer has a 40uF 8 ohm zoebel and a .47mH series inductor. Tweeter has 2 impedance compensation notches, a damping resistor, and a 5uF highpass cap. The tweeter section in particular can use some effort as the first order isn't the best way to protect the driver. I will at some point put a parallel coil in but it may well be oversized to keep the phase shift out of the passband.
http://img580.imageshack.us/img580/4381/finishedosguides3.jpg
Bass is meant to be big. A 6.5" is not a woofer.
Previous Topic: 2.5 way using two JBL 2226J with B&C DE 250 & H290 horn
Next Topic: Advent Loudspeakers
Current Time: Sun Nov 29 04:52:42 CST 2026
