Home » Audio » Speaker » 2.5 way using two JBL 2226J with B&C DE 250 & H290 horn
Re: 2.5 way using two JBL 2226J with B&C DE 250 & H290 horn [message #63161 is a reply to message #63158] Sun, 13 June 2010 17:59 Go to previous message
A few thoughts:
First, a minor clarification. The H290 is not a BiRadial horn. "BiRadial" is a JBL trademark and it is a constant directivity design that has a diffraction slot in the throat. The H290 is a radial horn that provides constant directivity in the horizontal plane. It has smooth side walls with no diffraction slots or edges. Just a quick clarification.
On the dual woofers, I'd do a 2.5 way arrangement, essentially running the top midwoofer and tweeter exactly the same way a four π does. That lets you leverage the design work I've already done, and minimizes your need to retest. The longest part of a speaker design is the test/measure/modify/retest cycle.
You can make the bottom box larger, if you want, for greater bass extension. Run the bottom woofer off the midwoofer crossover output, but add a large coil in series to limit its output to the bass range. It will have slow gradual rolloff, with a lot of overlap, and that will tend to mitigate floor bounce and any other room modes in the overlap region.
The seven π bass bin has a 5mH coil on the woofer, which is an 8Ω part. So if you're running 16Ω woofers, use a 10mH to 12mH coil instead. I use Erse Super Q coils for inductors this large.
I personally like using vented boxes, but with a slightly overdamped alignment. They have smooth gradual rolloff like a sealed box, but the excursion reduction and extra extension of a vented box. I think that's the best way to run woofers with electro-mechanical specs like the JBL 2226.
Previous Topic: Open Baffle or none at all?
Next Topic: The Bumma (tentative title)
Current Time: Sun Nov 22 05:45:44 CST 2026
