Home » Audio » General » Noise cancelling headphones
Re: Noise cancelling headphones [message #63157 is a reply to message #24893] Sun, 13 June 2010 05:00 Go to previous messageGo to previous message
Chuckles101 is currently offline  Chuckles101
It really depends on your budget - you need to understand that the cheaper ones are probably less effective that the ones that are more expensive. Do make sure that the noise you are hearing is periodic or rhythmic because that is when the headphones work best.
Previous Topic: Earbud or earpad
Next Topic: Digital Music Formats
Current Time: Sun Oct 25 21:08:03 CDT 2026
