Home » Audio » Thermionic Emissions » Audio Note power transformer
Re: Audio Note power transformer [message #63074 is a reply to message #63070] Sat, 05 June 2010 23:29 Go to previous messageGo to previous message
I've used dozens of those old-model Jensen/Audio Note PIO caps, and have been fortunate that (to my knowledge) not one has ever failed in service. Of course, I observe some extra precautions when using PIO caps. I avoid using them where very high internal chassis temperatures are present. I also use carbon composition grid stopper resistors with them, as the composition media is a poor conductor of heat, and helps isolate them from heat conducted from the power tube socket.
Many PIO caps have poor thermal stability; when cold their DC resistance may be hundreds of megohms, but it plummets as they become hot. I once saw a Chinese-made PIO totally lose it just a few minutes after turning the amp on, due to heat conducted into it through its leads. You could see the results of the DC leakage as it increased; the power tube began to glow in a tiny spot or two, and then eventually hotplated all over. I replaced it with a Jensen, and about 5 years of daily use later, the amp is still doing well.
Thermionic
Previous Topic: Why SE in SET amps?
Next Topic: Opinions please-New EL34, 6CA7, KT88 and 6550
Current Time: Fri Nov 13 21:24:44 CST 2026
