Home » Audio » Craftsmen » T-nuts, their care and feeding
Re: T-nuts, their care and feeding [message #63059 is a reply to message #29961] Thu, 03 June 2010 16:22 Go to previous messageGo to previous message
badman is currently offline  badman
Hurricane nuts work fine, so long as you coat the hole with glue prior to insertion (wood glue, or even white glue, work fine). You have to clean the threads when you do so. And don't hamfist it! If there's resistance when screwing in, back up and make sure you're properly aligned.
Bass is meant to be big. A 6.5" is not a woofer.
Previous Topic: Need to find a cabinet refinisher
Next Topic: Nostalgic DIYers
Current Time: Mon Nov 30 12:17:19 CST 2026
