Home » Audio » Thermionic Emissions » Audio Note power transformer
Re: Audio Note power transformer [message #63017 is a reply to message #63015] Tue, 01 June 2010 16:32 Go to previous messageGo to previous message
Yeah, that was my first thought too, a couple years ago when it first happened. I'm still not opposed to that, but I have found that the output tubes shift after a while and increase quiescent current. They still work, but shift up the load line. If you open it up and put a meter on it, you can see the voltage shifts.
I suppose I could put in pots to allow variable bias, adjusting as each tube ages and its characteristics drift. But instead, I've just installed cathode fuses and when one pops, I know the corresponding tube has shifted.
It also seems like 6550's drift more than KT88's. A 6550 will start to draw excessive current before it dies but a KT88 just goes out.
Have you had these kinds of experiences with 6550/KT88 tubes or something different? Do you think it might be something unique to the Audio Note Kit 2?
Previous Topic: Why SE in SET amps?
Next Topic: Opinions please-New EL34, 6CA7, KT88 and 6550
Current Time: Fri Nov 13 21:24:34 CST 2026
