Home » Audio » Room Acoustics » Blocking Sound Out of a Room
Re: Blocking Sound Out of a Room [message #62945 is a reply to message #62521] Fri, 28 May 2010 21:43 Go to previous messageGo to previous message
Mavare
You could also try the foam insulation sheets. You could use it while you are on the job and then take it down so you could see out of the window. A sheet of it doesn't cost much at a DIY store and you should be able to cut it to fit the window.
Previous Topic: studio speakers
Next Topic: Possible move
Current Time: Thu Oct 01 13:59:15 CDT 2026
