Home » Sponsored » Pi Speakers » insulation for the 2pi tower
Re: insulation for the 2pi tower [message #62707 is a reply to message #62703] Sat, 15 May 2010 18:14 Go to previous messageGo to previous message
I personally like R13 (fiberglass) insulation. I hate putting it in, as I'm always scratchy for the rest of the day. But it does exactly what I want it to do. I buy it in rolls, cut it to size, remove the vapor barrier and glue it in with white glue. I used to staple it in, but after many years I've stopped that because staples can sometimes vibrate loose and come out.
You should line the front, side and top and also span the cross section by laying a sheet on each set of braces, spanning the cross-section. Your braces can be a simple cross-brace, a window brace or a combination of both techniques.
Previous Topic: Pi kits?
Next Topic: 12PI plan or CAD ?
Current Time: Mon Oct 26 17:25:36 CDT 2026
