Home » Audio » Pro Sound » Build my own subs (to build or not to build...)
Re: Build my own subs [message #62537 is a reply to message #62536] Thu, 06 May 2010 15:18 Go to previous messageGo to previous message
In some cases, I think that makes sense. But you can't fix everything with signal processing. Setting a delay or making a filter is easy, but some acoustics problems can't be solved that way. Two examples that come to mind are cone breakup and destructive summing. Regarding destructive summing, if you can delay one source to match another, that will prevent it but once it has already occured, you can't correct it with a filter. Even if you boost power to the notch, you're just throwing power into a black hole.
Where I think this really shows up is self-interference from a boundary reflection. That's where multisubs work best, because they actually increase interference to smooth the modes. You can't correct the modes with processing, but you can mitigate the nulls with multiple sound sources. Naturally, it's best to get everything to sum properly but in some cases, that's not possible. So if you can't avoid interference, then the next best thing is to make the interference so dense, individual nodes can't be detected. It at least smooths the average sound field. This is an example of something that can't be accomplished with DSP. It requires an acoustic solution.
Previous Topic: Ultrasone Headphone Tip of the Month
Next Topic: Buying pick-ups
Current Time: Sun Nov 22 23:49:53 CST 2026
