Home » Audio » Radio » Any advice on long wire antenna
Re: Any advice on long wire antenna [message #62362 is a reply to message #62361] Sat, 17 April 2010 22:56 Go to previous messageGo to previous message
Long wire antennas are pretty simple critters, really. The longer the better, the higher the better, the further away from objects (particularly metal) the better. You can also use a tuned antenna (of specific length) but if you're tuning shortwave, sometimes you really want a broadband general purpose longwire.
There are a lot of good links on the internet, some some searches are in order. Here are a few good ones:
Previous Topic: philco model 111
Next Topic: Anode
Current Time: Fri Nov 13 06:48:11 CST 2026
