Home » Sponsored » Pi Speakers » 3 Pi Modifications
Re: 3 Pi Modifications [message #62291 is a reply to message #62277] Mon, 05 April 2010 15:16 Go to previous messageGo to previous message
The purpose of considering a sealed 3 Pi was to maximize the bass transient performance, better control the effects of room gain, and utilize the high excursion capabilities of the AE TD12S. The standard 3 Pi design uses a relatively small vent for a 12" woofer and compression at higher power levels is a concern. Would you consider a larger radius and/or flared vent in this design or is the 2.5" diameter and length vent optimal?
Thanks for the crossover advice as well. The iron core inductors model a little better due to the lower DCR, but are not acceptable if saturation is an issue. The 28 ohm resistence needed in the tweeter network could be created with Mills 8 and 20 ohm resistors if you believe that the 20 ohm resistor will be adequate to handle the relatively increased power. The Mills are rated as 12w resistors.
Previous Topic: Just received a set of 2 Pi's ...
Next Topic: 3pi/ 4pi plans
Current Time: Thu Nov 05 17:56:38 CST 2026
