Home » Sponsored » Pi Speakers » 3 Pi Modifications
3 Pi Modifications [message #62275] Sun, 04 April 2010 07:30 Go to previous message
Does the 3 Pi using the AE TD12S woofer perform well in a sealed cabinet? It looks good on paper with 2.6 cu ft. fully stuffed enclosure Bessel second order alignment (0.577 Q and f3 53Hz). The SBB4 vented alignment appears to have an f3 of about 43Hz and requires a 3.1 cu ft. box including the driver, horn, duct, and brace volumes. The cabinet would be lined on three sides with 1.5" open cell egg crate foam in the vented design and use a 4" flared port. Also, can Mills 15 and 12.5 ohm resistors and Jensen 15 ga P core inductors be substituted in the crossover? The latter have 400 watt ratings, +/-5% tolerance, and really low DCR. A 14 ga Erse air core on the 1.5 mH woofer coil is also a possibility, but has a higher DCR and costs twice as much. Thanks for your input.
Previous Topic: Just received a set of 2 Pi's ...
Next Topic: 3pi/ 4pi plans
Current Time: Thu Nov 05 17:56:50 CST 2026
