Home » Sponsored » Pi Speakers » Midrange Horn
Re: Midrange Horn [message #62262 is a reply to message #62261] Sat, 03 April 2010 19:47 Go to previous messageGo to previous message
There are probably a lot of things you can make "work" but I think you'll be happier in the end with more midbass capacity, and that's gonna require different drivers, in my opinion. I'm not saying you should do away with the Beta 10's necessarily, just that they are midrange drivers and can't do midbass no matter how you load them. If you were doing a home hifi setup, you could definitely use them but when pressed for max SPL, they're just not going to cut it down low.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 14:09:44 CDT 2026
