Home » Sponsored » Pi Speakers » 4 Pi Design Questions
| Re: 4 Pi Design Questions [message #62255 is a reply to message #62252] |
Sat, 03 April 2010 09:32   |
I use Dayton capacitors sometimes, yes. If a person orders a standard crossover with no upgrade options, they will have Jantzen, Erse, Solen or Dayton polypropylene caps.
But as for the Jantzen 22uF capacitor, you can use it where the schematic calls for 20uF. If we get an order for Z-Caps, that's what we use. We use Z-Standard caps in all positions except for the 0.47uF part, which is a Z-Superior. Not because I think it needs this, but because the 0.47uF size isn't available in the standard line. If someone was interested, we would be happy to use Z-Superior parts in all positions for a little extra cost, but we don't stock them. Most people that want the high-end caps want Auricaps.
As a related aside, 16Ω resistors are substituted with 15Ω parts and 12.5Ω resistors are used in place of 12Ω when Mills resistors are chosen. We use Dayton non-inductive 10 watt resistors for the standard option, Mills 12 watters for upgrades. The Zobel resistor is a non-inductive 100 watt, 8Ω part with a built-in heatsinking case which doubles as a mounting bracket. The 15 guage coil used in the 0.5mH position is actually a Jantzen air-core 0.47mH part. No other substitutions are required for any values, in any options or lines. All coils are Jantzen air-cores, whether 18 guage (standard) or 15 guage (upgrade), but the large 5mH coil used on the cornerhorns is an Erse Super-Q. All capacitors are poly caps.
By: mantha3 on Sat, 02 June 2012 08:56
By: mantha3 on Tue, 19 June 2012 07:52
By: mantha3 on Mon, 25 June 2012 17:15
By: mantha3 on Fri, 31 August 2012 15:13
Cabinet design, port placement and internal standing waves
By: mantha3 on Fri, 31 August 2012 18:39
Re: Cabinet design, port placement and internal standing waves
Current Time: Thu Nov 05 23:23:40 CST 2026
