Home » Sponsored » Pi Speakers » Midrange Horn
Re: Midrange Horn [message #62254 is a reply to message #62253] Sat, 03 April 2010 09:19 Go to previous messageGo to previous message
I didn't try that driver, no. I expect it would probably work pretty well, but it's hard to say - sometimes they surprise you. If you don't already have the drivers, it might be better to go with one of the drivers it has been tested with.
The midhorns are supposed to be ready this week, by the way. Finally!
One thing, the new shop prefers to build completed horns as opposed to flat packs. We kicked around the options, looked at the pros and cons, weighed the fact that flat pack kits are smaller but pre-assembled horns don't depend on user alignment of pieces during assembly.
In the end, we decided to provide midhorns assembled instead of as flat packs. You'll still need to build the cabinet to house it, but the precut and assembled horn will keep you from having to do the angled cuts and build a clamp/jig for assembly.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 14:12:22 CDT 2026
