Home » Audio » General » Video games (what's the best approach)
Re: Video games [message #62194 is a reply to message #62193] Fri, 26 March 2010 02:24 Go to previous messageGo to previous message
Sounds reasonable to me. With the DC/AC converter, it makes this pretty similar to the decisions you'd make for setting up a small home system. It's important that the devices you connect be able to work on converter power, which isn't a sine wave but rougher, so check that. You'll probably be OK. And like you've probably already found, for video signal connections, component is better than composite. Where you're running from a digital source (DVD), HDMI may be a good option as long as the signal run isn't too long.
Previous Topic: DJ Hero
Next Topic: Use memory card instead of CDs?
Current Time: Wed Nov 04 22:33:18 CST 2026
