Home » Sponsored » Pi Speakers » Just scored a pair of 3pi speakers!
Re: Just scored a pair of 3pi speakers! [message #62016 is a reply to message #62015] Mon, 08 March 2010 13:23 Go to previous messageGo to previous message
krikor is currently offline  krikor
Wayne Parham wrote on Mon, 08 March 2010 13:08
I suggest adding subs, because then you gain extension and smooth room modes at the same time.
Yes, I have a couple of ACI Force subs that I will be using, just don't have them setup for the 3Pi speakers yet. I wasn't expecting sub-woofer like extension, but until the woofer was wired properly I think it was cancelling some of the output with the other speaker. Bass definitely improved after I got them working correct.
Man, I'd like to be home listening to them right now rather than at work!
Do have plans available for you 3pi subwoofer as well?
thanks.
Previous Topic: 8 pi plans
Next Topic: 8 Pi horn and woofer?
Current Time: Fri Nov 06 06:42:18 CST 2026
