Home » Audio » Speaker » Optimum range JBL 2226
Re: JBL 2226 Usage [message #61787 is a reply to message #61786] Thu, 28 January 2010 21:07 Go to previous messageGo to previous message
I took out the 500hz crossover. Added 7mh for the woofer. It sounded really shouty with the FE167's running full out. I put a series 40uf oil cap in series with the 167's - sounded much better, still kind of shouty especially with horns (listening to Chet Baker). Next I added 4.5ohm 12W mills in series w/167 (it was the lowest value decent resistor pair I had on hand). Now it sounds very well balanced, maybe a touch tilted toward warm side. The 167's (IIRC) are 94db but being open baffle should be 97 in room (or 100? Not sure if it is +3 or +6db). with the 2226's being 97db I didn't think I'd need to pad down the top at all, but apparently yes. I'll live with this a bit and see how it goes. My next thought is to put a small HF comp cap across the 4.5 to see if we can get just a tad more out of the top end. FWIW, we're seeing peaks of 85db right now. Not too loud. Thanks for your suggestions, Wayne!
Previous Topic: Can anyone help me find this line array elemnts.
Next Topic: Klipsch
Current Time: Mon Nov 16 00:30:00 CST 2026
