Home » Sponsored » Pi Speakers » 4 Pi and 7 Pi bass response- More similar or different? (4 Pi VS 7 Pi )
Cornerhorns and constant directivity [message #61729 is a reply to message #61728] Fri, 15 January 2010 23:50 Go to previous messageGo to previous message
You're about right. I wouldn't expect much directivity control below 500Hz in freespace. The corners set the pattern for a couple octaves below that. In my opinion, this is the biggest benefit from corner placement: It gives the loudspeaker designer the opportunity to create a pattern having constant directivity all the way down to the Schroeder frequency.
On a related aside, I love good horn loaded loudspeakers and have always built them. But it cracks me up to watch people talk about cornerhorns and focus on the acoustic loading of a truncated basshorn. To me, that is trivial compared to the possibility of constant directivity. To build a loudspeaker designed to be placed in a corner and fail to incorporate constant directivity horns or waveguides is a huge mistake. The biggest benefit of a cornerhorn is how it directs the sound field above the Schroeder frequency, not below it. A good cornerhorn is probably the only configuration I know of that can provide constant directivity all the way down to the Schroeder frequency, approximately 100Hz or so.
Previous Topic: Three Pi sub
Next Topic: 4Pi Plans please.
Current Time: Thu Nov 05 22:52:53 CST 2026
