Home » Sponsored » Pi Speakers » 4 Pi and 7 Pi bass response- More similar or different? (4 Pi VS 7 Pi )
| Re: 4 Pi and 7 Pi bass response- More similar or different? [message #61709 is a reply to message #61567] |
Tue, 12 January 2010 22:39   |
Psychoacoustic
Messages: 75 Registered: May 2009
Viscount |
Finished the 7 Pi midhorn over the winter break. Gained some new woodworking skills, that's for sure! For example, take cursed thing to old mate down at the woodyard... put it through the tree-ripping bandsaw. Problem solved.
Had the crossovers built by Wayne on hand, mounted them in boxes. Removed the HF gear from this project http://audioroundtable.com/forum/index.php?t=msg&th=11661&start=0&
(4 Pi derivative), made a cover plate for the hole.
Mounted the HF unit in box and... SHA-ZAAM!
Have a couple of queries, if I may.
My three-year-old son has already made gestures towards reaching up and poking the dust caps. It's embarrasing to hear a grown man scream like a girl. Would acoustically-transparent cloth glued to the inside of the horn throat square be a problem?
What is the theory behind the 'backward' facing woofer? Is this to utilise the corner principle, negate floor bounce? In theory or practise, would a forward facing woofer as I currently have sound any different?
As pictured, the walls (to the left, curtains covering ancillaries, to the right window curtains) would diffract sonic reflections from the midhorn (and tweeter)- yes? Currently in the process of constructing doors to cover both of these curtained areas (due to a desire to secure the hi-fi gear and dust is a big problem on these components from the curtains). Which surface would be optimal- a diffractive, reflective, absorbative (i.e. rigid fibreglass acoustic panel) or combination from the above?
Attachment: before.JPG
(Size: 58.80KB, Downloaded 6659 times)
Attachment: woodshop.JPG
(Size: 81.65KB, Downloaded 6854 times)
Attachment: close up.JPG
(Size: 70.17KB, Downloaded 13928 times)
Attachment: room 7 Pi.JPG
(Size: 98.71KB, Downloaded 6692 times)
By: tom-m on Thu, 17 December 2009 18:32
By: tom-m on Fri, 18 December 2009 09:51
By: tom-m on Fri, 18 December 2009 16:52
By: tom-m on Mon, 28 December 2009 13:00
By: feket663 on Sun, 27 December 2009 11:02
By: feket663 on Sun, 27 December 2009 14:53
By: feket663 on Mon, 28 December 2009 14:56
Cornerhorn Ruminations
Room Treatments
By: tom-m on Wed, 13 January 2010 23:22
seven π photos
By: tom-m on Fri, 15 January 2010 15:31
By: tom-m on Fri, 15 January 2010 22:01
Cornerhorns and constant directivity
Crossover considerations - power handling, frequency, slope, etc.
Current Time: Thu Nov 05 22:52:31 CST 2026
