Home » Sponsored » Pi Speakers » 1-Pi/2-Pi (Subjective Qualities)
Re: 1-Pi/2-Pi [message #61684 is a reply to message #61673] Thu, 07 January 2010 16:00 Go to previous messageGo to previous message
RDLewis is currently offline  RDLewis
Thank you gentlemen for your replies, the Alpha 10/2-Pi looks like the direction I should follow.
After you sent me the Plans for the above, I did some more searches for the them on your site. To one answer you said that you used MJking's worksheets to model the Towers. Now I have the original "free" version so I put the specs and dimensions and the results looked good. Out of interest I tried out the above using his "ML TQWT" and managed to come up with a very similar response (with different Port size). The box would be narrower and shorter, which would be more acceptable in my room. Modeling is all very well, but would it sound as good?? Though MJK does state that TL's, reflex, MLTQWT all use the same equations.
What is your opinion of the above, have you tried TL's? Do you have any frequency/impedance, charts, etc, for the 2-Pi tower
I would be grateful for any further advice
Roy
Previous Topic: Pi 2 plans
Next Topic: 4Pi
Current Time: Thu Nov 19 14:14:35 CST 2026
