Home » Sponsored » Pi Speakers » 4 Pi and 7 Pi bass response- More similar or different? (4 Pi VS 7 Pi )
Re: 4 Pi and 7 Pi bass response- More similar or different? [message #61622 is a reply to message #61576] Mon, 28 December 2009 13:00 Go to previous messageGo to previous message
Hi Wayne,
I did a rough build of a midhorn, to get a perspective on its size, and to see if I ran into any problems. I just made it with butt joints, using 0.75 in plywood. The butt joints don't meet flat, I guess because of the flare of the horn. I used the dimensions from the link I posted a few replies up. Does the full 7pi plans have more detailed construction of the midhorns? If so, I may need them.
Also, I will probably buy 7pi crossovers from you, but wanted to know what is the crossover point between the woofer and midhorn?
Here are 2 pics of my rough build midhorn.
Thanks,
Tom
index.php?t=getfile&id=130&private=0
index.php?t=getfile&id=131&private=0
  • Attachment: horn01.jpg
    (Size: 51.73KB, Downloaded 8029 times)
  • Attachment: horn02.jpg
    (Size: 57.48KB, Downloaded 7908 times)
Previous Topic: Three Pi sub
Next Topic: 4Pi Plans please.
Current Time: Sun Sep 27 07:52:41 CDT 2026
